In order to condition the installation of a registry value, select it from "Registry" page and press F8. This will take you to its component in "Organisation" page. You should enter the following condition for the registry value associated with the keyboard checkbox :
where "CheckBox" is the selected value of the KEYBOARDCHECK_PROP checkbox.
In this way, the keyboard registry value will be installed only if the corresponding checkbox is selected.
Repeat this method for the other registry key.
If this is not helpful, please send us the .AIP (project) and a
verbose log of the installation to
support at advancedinstaller dot com so we can investigate them.
Sorin
