WGPuckett
Could Not Access Network Location
Trying my first simple install. No matter what I do, when I test my install I get this message:
I tried to search for this message in the form and got 138 hits. I went through 15 or 20 of the "hits" and found nothing.
Cosmin
Please make sure you have correctly set the installation folders and you have added local files in your project (from the hard-disk).
If the problem persists please build your project and use the "Run and Log" option in the "Project" menu. Please send us the .aip file and the log (if they do not contain confidential information) to support at advancedinstaller dot com so we can investigate the problem.
Cosmin
