amorpeth
Clone Project
Hey,
I wanted to be be able to copy a complex project and re-use on another project with similar requirements.
I tried creating a template and then starting a new one from the template but I get the following error:
[SEH_AV_READ_NULLPTR] ACCESS_VIOLATION (0xc0000005) at address [0x011d0d9a]
Advanced Installer 14.1 build 79372
*** Stack Trace (x86) ***
[0x011d0d9a] -----
[0x01000000] MODULE_BASE_ADDRESS
I also tried copying the project directory and sanitising for the new project. This largely works, however I am stuck with the "Features" from the copied project, and I cannot delete them as the delete option is greyed out.
Any ideas how I could achieve what I am after?
Andrew
Re: Clone Project
Hello Andrew,
Unfortunately this error is caused by a recent issue appeared in our latest version of Advanced Installer (14.1). We already started working on a fix and as soon as it will be available we will update this thread.
Until then, I'm afraid there is no workaround you can use.
amorpeth
Re: Clone Project
Thanks for the heads up!
Are there any pointers to copying the file structure? Can old features be deleted? Copying seems to work, but just stuck with old features.
Re: Clone Project
We have already released a fix included in the new version released today. So, please install and use our new AI 14.1.1 version and this should fix the issue.
amorpeth
Re: Clone Project
Great the new version no longer crashes! but... it still includes all the features from the project I created the template from, and I still cant delete them because this action is grayed out. Why cant I remove these from the template?
Re: Clone Project
A feature can be removed only when it contains no components. In order to delete a feature you should first move all of its containing components under a new feature. Then try again to remove the feature and the "Delete" option should be enabled.
Let us know if this helped.
amorpeth
Re: Clone Project
Im not sure how to do what you mean? How can I check and move components?
Re: Clone Project
Please take a look on our "Move components" video tutorial.
Just drag and drop them from the source feature to the targeted one.
amorpeth
Re: Clone Project
Thanks! That did the trick :)
Re: Clone Project
You're always welcome.
