jcordes133
Installer removes files it did not create
Recently some change has made my installers begin to delete files that they did not create on unistall.
The behavior is:
1 build installer ver1.0.0 and install it.
2. run the installed app and it creates a few files that the installer did not like C:\program files\mycompany\myapp\printerconfig.json
3. build installer ver1.0.1 and run it (it is set to remove first then install)
4. C:\program files\mycompany\myapp\printerconfig.json is removed during the install/upgrade process.
Why would the installer ever remove a file that it did not know exists?
Sorin
Re: Installer removes files it did not create
This might happen if your project contains a File Removal operation or a Folder Removal operation
The file removal operation is displayed as a file in "Files and folders" page. The folder removal operation changes the icon of the folder from "Files and Folders". Please take a look on the attached screenshots that describe both these operations.
Sorin
