aeplengg
Install prerequisites in silent mode
Hello Advanced Installer,
I am using ADI 14.1.1 to build setup which includes prerequisites.
I have created one VB6 package using Visual basic Package and Deployment wizard and this package i have used as Pre-install prerequisites in ADI.
I want my prerequisites should install in silent mode. If I set install command lines as '/quiet' for prerequisite, the ADI setup at installation time prompt error 'Invalid command-line parameters. Unable to continue' followed by Visual basic setup toolkit error.
How to solve this issue?
Swati
Error 2.png (859.09 KiB) Viewed 7532 times
Error 1.png (852.16 KiB) Viewed 7532 times
Sorin
Re: Install prerequisites in silent mode
Is your prerequisite package an MSI? The command line to run an MSI package in silent mode is
/qn
You should configure all the Install Command Lines (Full UI, Basic UI, Silent- no UI) as shown in the attached screenshot.
Sorin
aeplengg
Hello Sorin,
My prerequisites package contains CAB, LST and EXE file. Attached screenshot for reference.
Swati
ADI Prerequisite.png (79.1 KiB) Viewed 7523 times
Sorin
Please send us the .AIP (project) of the VB6 Package prerequisite at support at advancedinstaller dot com so we can investigate it.
Also, if you could send us a download link to its built setup package files so we can fully test them on our side this will be great.
Sorin
