skywalker
Which version for SQL and IIs
I want to know which version I need.
Some points that I need:
- prerequisties (framework 3.5 etc.)
- IIs install with configuration
- SQL Server 2014 express mixed mode install with defined password, reporting service off
This should be done on Windows 10.
Can I do this with the Advanced Installer Professional or do I need Enterprise?
thanks in advance
Re: Which version for SQL and IIs
Installing prerequisites and configuring IIS websites is available in the Professional edition of Advanced Installer. Also, installing SQL Server as a prerequisite is available in the Professional edition, but working with SQL Databases is only available in an Enterprise or higher edition.
However, there is a 30-days trial period available, so you can test Advanced Installer and see all the features you need and the edition suitable for you. Also, if you purchase a Professional edition, you can upgrade anytime to the Enterprise edition with no extra cost (paying just the difference between the two editions).
Just let me know if you have other questions.
