RamonaVV
Mixed 32/64-bit & merge modules
All our projects with mixed MSM platforms shows the same build error with the AI version 14.1.1.
With the AI version 13.8.1 the building is successful.
Rebuilding the MSM's with the version 14.1.1 does not fix the problem.
We had to revert to the version 13.8.1. Please solve it asap!
If you need AIP samples I can send you as many as you want.
Re: Mixed 32/64-bit & merge modules
I've tested your scenario and everything is working as expected. Please make sure that your project is of Mixed 32/64-bit matching the platform (runs as a 32-bit package on 32-bit systems and as a 64-bit package on x64 systems).
Can you please make sure that you correctly configured the merge module during the Mixed Wizard Configuration? You can use the following image as reference:
MixedPackage Organization.png (45.65 KiB) Viewed 5220 times
This wizard will launch when the "Mixed 32/64-bit matching the platform" package type is selected in the Install Parameters page. You can reopen the wizard by using the [ ... ] button placed next to the “Package Type” option.
You can send me the .AIP(project file) that works in the 13.8.1 version of Advanced Installer and the .AIP(project file) that does not work in the 14.1.1 version of Advanced Installer.
RamonaVV
I attached an image with my settings. With AI 13.8.1 my projects can be build.
I send you an AIP by e-mail.
ai colaj.png (66.82 KiB) Viewed 5216 times
Indeed, this is an Advanced Installer issue that will be fixed in the next version of Advanced Installer.
Thank you for bringing it to our attention.
RamonaVV
I installed the version 14.2. The problem persist. Do you have an estimation for the fix?
Ramona Vasilescu
Hello Ramona,
A fix will be included in our next version of Advanced Installer (14.3) which should be out in a couple of months from now on (at most 2-3 months). We will update this thread as soon as the fix will be released.
This was fixed in version 14.3 of Advanced Installer released on September 18th, 2017.
