Tiles
Missing product name in file association dialog with german text
I noticed that with german language the product name is missing in the Select File associations dialog.
Is there a workaround available?
Kind regards
Tiles
Sorin
Re: Missing product name in file association dialog with german text
Yes, I can reproduce and confirm this issue. This problem is triggered by the fact that in the German translation's default string the "[ProductName]" property is misspelled "[Productname]". As Windows Installer properties names are case sensitive, at install time the content of "Productname" property (which is empty) will be inserted in the string instead of the actual product name.
A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
Until then, as a workaround, you could edit the German string by going to "Translations" page, "Default Strings" tab. Select the default string: "Bitte wählen Sie die Dateitypen, die Sie automatisch mit [Productname] öffnen wollen:" and replace [Productname] with [ProductName]. Then click "Save changes in a dictionary from repository" and build the project again.
Please let me know if you have any other questions.
Sorin
Tiles
Many thanks for the workaround :)
Kind regards
Tiles
Sorin
Hello Tiles,
You are welcome! Please let me know if you have any other questions.
Sorin
This was fixed in version 14.3 of Advanced Installer released on September 18th, 2017.
