Tiles
Second installation language problem
I have two installers. One for the 64 bit version of my software, one for 32 bit version of my software. The installers are both identical at the feature side. They both have in the translations section the same settings: Create only a multilingual package and Automatically use system language for installation ticked.
When i first install the 64 Bit version, then the installer proceeds with my OS language. German. When i install the 32 bit version, then the installer shows english texts.
And the other way around it's the same. When i first install the 32 Bit version, then the installer proceeds with my OS language. German. When i install the 64 bit version, then the installer shows english texts.
And also, when i use just one of them, and start the installer again, with already installed software, then the installer language is english.
Is there a special setting to prevent this? So that the second installer also installs with the OS language?
Kind regards
Tiles
Re: Second installation language problem
Hi Tiles,
Can you go in the "Product Details" page, "Product IDs" tab, set the same Product Code for all the languages and see if this helps? If you do not want to allow the installation of both 32-bit and 64-bit packages at the same time, you can set the same Product Code in both packages.
Tiles
Many thanks Eusebiu, this did the trick :)
May i suggest to add a button where you can generate the same key for all languages?
Kind regards
Tiles
You're always welcome Tiles.
I've forwarded your request to our development team and hopefully such UI option will be considered in the future. Thank you for your suggestion.
