Protection
Manual Digital Signing
Hi AI team,
we have problem with installation signed application. We used SignTool.exe (from Windows SDK) manually for signing installation file. We get this error on begin of installation. Installation file is signed with SHA1 and SHA256. Our project contains more EXE and MSI files inside the installation and they are signed same (manually and dual certificate).
If we do not sign final installation file the installation process is without problem.
Do you know where problem is?
Sorin
Re: Manual Digital Signing
This behaviour is triggered by the fact that the when you sign the EXE manually, the embedded MSI will not be signed, thus a signature mismatch will be detected. If you have to sign the package manually (outside Advanced Installer) you should build it with resources outside and sign the MSI file as well.
We recommend signing the package using our Digital Signature Page.
Sorin
Protection
Hi Sorin and thanks for describe the situation.
We will try sign our product with AI signing tool.
Thanks once again and have a nice day.
Sorin
You are welcome! Should there be any difficulty implementing something, please let me know and I will gladly assist!
Sorin
