h353655
Set attribute value conditionally
I would like to set the value of an attribute in an xml file conditionally depending on the value of a Property.
Sort of:
[MyProp]="somevalue" ? "truevalue" : "falsevalue"
Picture added.
Re: Set attribute value conditionally
In order to achieve this you can use another property in the "Value" field that will be set based conditionally through a "Set installer property" custom action.
h353655
Damn...I'd hoped to skip that extra step
Another workaround is to duplicate the element that contains that attribute, but set different values for the attribute in each element, then use your property as a conditions for the installation of the two elements in the "Element Settings" tab.
