Ruben
Documentation for Search Value Ranges
Hello Advancedinstaller,
we use different searches on the Search Page.
[img]
[/img]
A Search is created quickly. And all the searches end up with some RESULT_PROPERTY.
But to use the result, I often had a painful time with trial and error.
I always wonder:
- Is the result property a String, a Number or a Boolean ?
- With non-successful searches, will it be "no value" or an "emty value" and makes that a difference ?
- and how to compare the RESULT_PROPERTY ?
Is it right to write something like RESULT_PROPERTY=0 ?
Hey, it might also be...
  • RESULT_PROPERTY="0"
    RESULT_PROPERTY=""
    NOT RESULT_PROPERTY
So, is there a documentation of the return value ranges of successful and unsuccessful searches ?
Many thanks,
Ruben
Sorin
Re: Documentation for Search Value Ranges
Hello Ruben,
The result of the search is a string.
For non successful searches the RESULT_PROPERTY will have no value. In Windows Installer properties case, an empty value is the same thing with a no value.
This, as any other Windows Installer property could be compared using the "Comparative operators". Please take a look here : Comparative operators
In the case of an unsuccessful search you could write NOT RESULT_PROPERTY
As I previously said, the unsuccessful searches return no result (the value is empty)
The successful searches return the value configured in the "Search" page. For example if you search a registry value, you have the option to select the type of the search. For example in "Retrieve the raw value" case the RESULT_PROPERTY will receive the value contained by the searched key.
If you search for a file, in case of a successful search, the RESULT_PROPERTY will store the full path of the file(including the file name and extension).
We will try to improve our documentation regarding this subject. Thank you for your suggestion.
Sorin
