skingswell
Test Sql Connection - Nothing Happens??
I am using the TestODBCConnection Custom action to test the credentials of the SQL Server connection but I cannot get this working properly
I have a dialog which browses the SQL servers on the network and an option for the user to select how they wish to connect (Trusted/UserName & Password). Before progressing to the next dialog which displays the databases for the selected SQL server I want to test that the user credentials are valid. I have added the custom action to TestODBCConnection (see attached example of the configuration).
When I Click on 'Test Sql Connection' nothing happens. However when I progress to the next dialog (SQL Databases) and then select back the SQL Connection Result displays 'Connection Successful'
To be able to perform a 'Test Sql Connection' must the user first select a database? What am I doing wrong? Can I test the connection without specifying a database?
skingswell
Re: Test Sql Connection - Nothing Happens??
Test SQL Connection.PNG (14.68 KiB) Viewed 3852 times
I'm not sure why this happens. Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
skingswell
Hi Daniel
Many thanks for offering to look at the project.
I managed to get it working using the SQLServerConnectionDlg instead of doing it myself. Seems to be working :-)
Regards
You're always welcome.
