wasilisa
ODBC Oracle driver problem
I have the problem with ODBC Oracle driver. I configured the oracle connection.
SQL connection.jpg (142.5 KiB) Viewed 4994 times
And the test of oracle connection is successful.
SQL Connection test.jpg (50.74 KiB) Viewed 4994 times
BUT during installation, the connection does not work.
SQL connection during installation.jpg (81.83 KiB) Viewed 4994 times
I use the custom action “TestODBCConnection” with “Driver=[\{][ODBC_RES_PROP][\}];Server=[SERVER_PROP];Uid=[USERNAME_PROP];Pwd=[PASSWORD_PROP];” (as described in http://www.advancedinstaller.com/user-g ... ction.html). The Connection not work. I get the following error message: SQL_STATE: IM002.
Why does not the connection work to Oracle?
Re: ODBC Oracle driver problem
From what I see during the test operation for the ODBC connection parameters you are using a different ODBC driver name ("ODBC Resource" field) than the driver name you set up in the "SQL Databases" page. So, can you please fill in the "ODBC Driver" field from "SQL Databases" page the same driver name you use during installation on your SQLServerConnection dialog?
Also, in the same page please uncheck the "Use 64-bit ODBC resource" option and rebuild and test again your setup project? Our TestODBCConnection action test the parameters only against 32-bit drivers, so since the connection test was successful you should configure the SQL Connection from the "SQL Databases" page of your project to use a 32-bit ODBC driver too.
Let us know if this helped.
wasilisa
The drivers are the same, I posted wrong screenshot. Too bad that the function "TestODBCConnection" only runs with 32-bit driver. I do not use this function anymore and still have the connection to Oracle and can run scripts.
But the connection is always redirected to local Oracle database. That means no matter what a database server I enter, the scripts are run on local databak. In the log output is: DRIVER_CONNECT(Predef):
[Driver={Oracle in OraDB12Home4};Server=lb344/orcl12.world;Port=1521;Uid=system;Pwd=oracle;].
The connection in SQL Developer and ODBC management work. What could be the problem that the connection to the Oracle server doesn't work. We have the domain here. Can it be because of this?
Thanks in advance
I apologize for my delayed reply. Last week I was out of the office.
This is strange. I never encountered this behavior. the connection to be set up under a remote database but to run under a local database.
Could you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
