Borgas
Exit Dialog is closing after selecting Release Notes
When user selects Release Notes it closes the Exit dialog.
How can i precent this?
Re: Exit Dialog is closing after selecting Release Notes
I'm afraid that this is the normal behavior. The dialog closes when the "Readme" button is clicked. In order to prevent this, you can create a new image button which will execute a "Launch file" custom action that will open the release notes file. In this case, you do not need to use the "View Readme" option from the "Finish Actions" tab anymore.
