Borgas
Option checked by default in exitdialog not executing
When option checked by default in exitdialog is not execution that option when i click Finish button.
Re: Option checked by default in exitdialog not executing
I'm afraid that this is the default implementation in the "Surface" theme. If you want to launch your application when the "Finish" button is pressed, you can select the "Run" button, copy the predefined event available in the "Published Events" tab, then select the "Finish" button and paste the event in its related "Published Events" tab.
