Borgas
Version not updating instance version number
After updating version of an specifik Instance. Next time i run setup the specified version is not showing that it has been updated
Re: Version not updating instance version number
Hello Boris,
Can you consistently replicate this behavior? If so, can you send us the AIP (project file) which replicates the issue and a detailed test case to support at advancedinstaller dot com so we can try to replicate this too?
Borgas
Yes
setup.aip
(653.87 KiB) Downloaded 406 times
Hello Boris,
Can you please also give us a detailed step by step test case you use to build your setup projects and the steps you did to update the old instance version?
