elou
Software installation not recognized when installing with bootstrap on MSI
I have an application which may be installed with both Bootstraped-Setup and MSI.
Both Setups are build in the same AI-project with the same product-code and upgrade-code.
Both Setups are signed.
After the Application has been installed with the MSI, running the bootstrapped-setup produce an
Another version of this product is already installed
Running the MSI installer will correctly open the "repair" dialog.
Is it possible to make both Setup compatible with each other?
Regards, Éric.
Try to install the same version of the software with bootstrap on a previous identical version installed with MSI
Bildschirmfoto 2017-09-13 um 08.52.18.png (68.1 KiB) Viewed 4930 times
Re: Software installation not recognized whein installing with bootstrap on MSI
Hello Éric,
Unfortunately this scenario is not supported. Could you give us more details about why would you need to support this scenario? To use on the same machine two package types (EXE and MSI) of the same product version.
elou
Thanks for your reply,
we would like to use the pretty design possibilties that offer the Bootstrap for some customers.
For other customers wo need large deployment of our application a MSI is the better choice.
For that reason we would like to provide both setups.
Of course it will not be encourage to use one setup on the other, but I don't want to prevent the customers to do that if they wanted to..
Regards, Éric.
elou
Re: Software installation not recognized when installing with bootstrap on MSI
has I know, the bootstrap Version of the Setup first generate a MSI file which will be packed in the EXE file.
So I do not understand while a compatibility with both formats should not be supported.
It ist possible to behave the MSI file which will be packed in the bootstraped Setup while AI build?
Regards, Éric.
Hello Éric,
This is not possible because for each different build a different PackageCode is generated. This is a Windows Installer requirement.
Unfortunately there is no workaround for your scenario. Thank you for your understanding.
