ehardin
files end up in multiple cab files
AI ver. 8.0.2
Files added in "Files and Folders" assigned to a particular Feature when added (dropdown box at top right) end up in multiple cab files.
If I open Custom Behavior -> Table Editor -> FeatureComponents I see the files for any specific feature listed once for that feature (FeatureA for instance).
In Builds -> Build Content I have 3 separate features listed (FeatureA, B, and C for instance) and a Prerequisite.
In Builds -> Configuration I have "Archive installation files into CAB files" and "Compress CAB files for smaller size" and "One CAB archive per feature".
When I do a build I end up with the 3 feature cab files BUT
all of the correct files for FeatureA are there but also the Prerequisite file.
FeatureB CAB contains ALL of the files from FeatureA, B, and C and also the same Prerequisite file
FeatureC CAB contains ALL of the files from FeatureA and C and also the same Prerequisite file.
How do I fix this?
Ed
Re: files end up in multiple cab files
Hi Ed,
I'm not sure why you encounter this problem. Can you please test this in the latest version of Advanced Installer and see if it works?
