http://www.advancedinstaller.com/user-g ... ation.html
which contains the following text:
I can find "Install Execution Stage" -> "Add Resources", but I cannot find anywhere to set "deferred" with "no impersonation". Where is it?If the installation will run on Windows Vista or above, the custom action should be moved under "Install Execution Stage" -> "Add Resources". Also, it should be set as "deferred" with "no impersonation".
Also, maybe time to update the documentation? "Vista or above" is a very common case these days.
