Protection
Calling function from standard DLL
Hi AI team,
In our project user can insert license key but we need to check validity of key.
I have tried console application but AI can not save return code as property (0 - OK, 1 - error), so I decided to use .dll and call function.
I followed this instructions (http://www.advancedinstaller.com/user-g ... rp-ca.html). When i trigger button for validate license key (call DLL function) it ends with error "Function 'LicenseNumberCustomAction' not found in DLL". DLL file is in the temp file.
What am i doing wrong?
Or is there way how to save output (return code) from console application into property?
Thanks.
Protection
Re: Calling function from standard DLL
Problem solved. We had wrong CA dll file.
I'm glad you solved the problem. Just let us know if there is anything else that we can help you with.
