dhaval0129
Unable to run the installer
Every time I run the installer to update the file, there is error which shows up--"There is problem with windows installer package....", check attached screen shot. I am also attaching necessary files. I have not changed anything since last time. I also tried to update to the latest version of advanced installer still it did not fix the issue.
ClarityUpdater.aip
(119.13 KiB) Downloaded 361 times
MSI9701.LOG
(605.72 KiB) Downloaded 470 times
Sorin
Re: Unable to run the installer
I've analyzed your log file and project and it seems that "clarityupdate.bat" custom action fails (it has an exit code different than 0). Please debug the batch file.
If you want to continue the installation even if this custom action fails, you could disable "Fail Installation if custom action returns an error" option for this custom action.
Sorin
