narendracool
Error while creating SSL website under IIS
Hi ,
I require your help when creating a new website under IIS with SSL bindings.I have attached a self signed certificate using the option "Use Existing server certificate".
During install time a error is thrown "There was an error while processing the digital certificate for WebSite".
I am using Advanced Installer version 13.8.1. Have attached error logs and screen shot
ErrorFile.txt
(276.97 KiB) Downloaded 271 times
Re: Error while creating SSL website under IIS
This may happen if the certificate with the thumbprint specified doesn't exist imported into the IIS Server certificate store. Can you please make sure the related certificates is already installed on your target machine?
Please proceed like this:
1. open the IIS Manager (Win + R -> inetmgr) and go to "Server Certificates" section
2. make sure there is found a certificate with the following thumbprint:
C80FEC5E6C8B5B81A6B25CCC73E5D45A2DE1A960
