gcruz
Search in registry show error if not found reg key
Hello !!
I have created an Search to obtain a key value from registry. When test this search, if the key not exists returns empty value, but when running the installer search shows an error. (See the attachment)
Is possible to hide this error message and take a default value from another property??
Thanks !!
Guillermo
Sorin
Re: Search in registry show error if not found reg key
You could initialize the result property from "Install Parameters" page. Just add a new property in the "Properties" section, named the same as your result property, with a default value configured as a valid path (for example "C:\Default Folder"). If the search will not return a result the default value will be maintained.
If this isn't helpful, please send us the .AIP project to support at advancedinstaller dot com so we can have a better view of your scenario.
Sorin
