gmeisel
Custom Action: How to Ignore return codes?
I am using a custom action to automatically launch a third party installation executable and have no control of any of the codes that may be returned from it. How can I get the updater to not show the ambiguous error page reporting that some files didn't install correctly. This seems to happen even if the user completely finishes the installation of the third party program. How can I get it to not show this error page? The installation of this custom feature is optional, and users can cancel it without harm to our main program. It is confusing and worrying our customers
Re: Custom Action: How to Ignore return codes?
Indeed, any code besides zero that a executable custom action returns is interpreted as an error by Windows Installer.
A possible fix for this would be to ignore the return code of the executable file. For this, you can go in the Custom Actions view and disable the "Fail installation if custom action returns an error" option from the custom action properties.
If this does not solve the issue, can you please send us the .AIP (project),a screnshoot of the error and verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
gmeisel
Dan,
Thank you for your reply, but I have already researched those pages and the one thing that is never made clear, is how exactly do you add the ignore return code flag into AI interface? I already tried inserting both the the constant "msidbCustomActionTypeContinue" or its decimal "64", into AI's Execution Condition with no luck.
Can you please outline just how you are supposed to implement it?
gmeisel
Dan,
Attached are the files you requested. I did review the log and see that yes the third party installer is apparently returning a "1". I just need to how to get AI to ignore it.
AV-Playback Lite.aip
(87.1 KiB) Downloaded 787 times
gmeisel
Dan,
If I try to attach the log file I get "Sorry, the board attachment quota has been reached." error
Sorry
gmeisel
Dan,
I am re-thinking my position on this issue... It appears that perhaps the error prompt isn't from the custom actions at all, instead it is something else. I have created a separate update version of our installer. It does not contain any custom actions, but yet when it is executed inside the Updater, the updater is the one that is reporting the error. Just so you know, when either the full or update version is started directly from windows explorer, installation goes fine and no errors appear. It is only when it is executed via you updater utility.
Any thoughts?
Hello Gmeisel
After some investigation of your project it seems that your update install detection may not be set up correctly.
Could you set up your Updates Configuration project --> Update Install Detection --> Registry Value to the following value:
HKLM\SOFTWARE\AV-Playback\Version
Any update defined in the Updates Configuration file uses a detection criteria. This criteria is usually a file or a registry entry which contains the package version. If it's not met after the update is installed, the Updater will show this message. Therefore,you need to make sure that you specified a correct file or registry entry in the Installed Detection tab of the Update Properties page.
Please let us know if this has solved the issue.
gmeisel
Dan,
You suggestion also tips on another issue I see... It appears that the installer is not actually writing to the Registry? I have experimented with a number of different combinations but each time it never creates the new reg keys, (if none exist.)
Thoughts?
Hello Gmeisel,
If you are running a 32-bit installation on a 64-bit OS, your registry entries are automatically redirected to WOW6432Node. This is standard Windows Installer behaviour.
Please refer to the following article for more information Wow6432Node Registry Key.
We have tested your installation on a clean machine with 64-bit OS and it created the following entries:
HKLM\Software\Wow6432Node\AV-Playback
Could you please check if this is the case?
gmeisel
Yes, I just figured that out, and yes I now have it including Wow6432Node in the path. Now at least the updater detects that the current version exists and doesn't allow the download. Still a bit inconclusive to whether or not it will stop the error prompt. Every time I test against and earlier version I still get the error.
Hello Gmeisel,
Please note that you do not have to include "Wow6432Node" in your path as it is automatically redirected there by Windows Installer.Keep in mind that this happens when you are running a 32-bit application on a 64-bit OS.
If you are receving the error promt, but your update is downloaded and installed, it means is that your "Update Installed Detection" is not set up correctly.
Also, please take a look at the "Do not try to detect if the update was installed" option from Update Install Detection tab.This option disables detecting the update installation after the update was installed and you won't be notified if your update installed succesfully either.
