tomas.jotov
Env variable (e.g .path) in MSI
Hello, I have a problem setting system path.
If I use EXE target, it's OK
But if I use MSI build - instead of adding string to path variable it creates a new property:
Environemnt.Name.Path with value Environemnt.Value.Path
which is obviously wrong
AI 14.4, Windows 10 (fall creators update)
Sorin
Re: Env variable (e.g .path) in MSI
Could you please send us the .AIP (project) a to support at advancedinstaller dot com so we can investigate it?
Sorin
