mathiaso
Modify installation draw issue
Just updated to latest version of Advanced installer since I had an issue with the drawing of the dialog in modify installation.
Sadly updating did not work. Is there an issue with this, or is my dialog simply wrong in some way?
2017-11-17 15.53.51.jpg (24.07 KiB) Viewed 3084 times
Re: Modify installation draw issue
When using any other theme aside from the "Classic" one there are two things that are a must in order for them to run correctly on both install and uninstall/modify:
- the Enhanced User Interface should be set to "Always(install, uninstall and maintenance)" in the Themes page --> Settings --> User Interface.
- your package should be an EXE since the Enhanced User Interface used for these themes is handled by our EXE bootstrapper. You can find this option in the Builds Page --> Package Type.
Please check these and let us know if you are still encountering issues.
