rmoc
MSI 64-bit ProgramFiles (x86)
I have created a 64Bit MSI package.
But when I start the setup under Windows 10 (64Bit) the installation directory "C: \Program Files (x86)" is used.
Why?
Re: MSI 64-bit ProgramFiles (x86)
I'm not so sure why this happens. Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
Also, please try to give us a step by step test case too.
rmoc
Hi Daniel,
Thank you for your answer. An example project is attached.
René
Your Application.aip
(15.93 KiB) Downloaded 599 times
logFile.txt
(213.81 KiB) Downloaded 544 times
Hello René,
This happens because you are running the setup package built with "Build" buildname. Please note that the settings in our "Install Parameters" page must be set for each build included into your setup package.
Please proceed like this:
1. go to "Install Parameters" page and in the top toolbar select the "Install Parameters" tab
2. in the builds combo box select your "Build" build
3. set the package type for this build to 64-bit option too and rebuild the project
Test again the rebuilt setup package.
rmoc
Hello, Daniel,
Thank you for this tip. I see the selection of the build configuration for the first time in the toolbar. :-)
Kind regards,
René
You are always welcome René.
