shenyongran
Custom Launch Conditions BUG
Custom Launch Conditions MSI build normal, build EXE file can not detect the start condition. Do not know if you have this situation, Advanced Installer 14.5.2 version, never before, I do not know if Advanced Installer 14.5.2 BUG. Officials can test to see.
Re: Custom Launch Conditions BUG
Can you please give us more details about the scenario? Maybe exemplify a bit more or attach some screenshots.
If you could iterate a detailed step by step test case we can follow to replicate the issue this will be great. Or maybe you can attach a sample replicating the issue.
shenyongran
Made an example
Run Tips.jpg (5.22 KiB) Viewed 7338 times
Custom Launch Conditions.jpg (21.24 KiB) Viewed 7338 times
shenyongran
File
Your Application.rar
MSI file
(993.93 KiB) Downloaded 440 times
EXE file
(823.97 KiB) Downloaded 663 times
AIP file
(3.49 KiB) Downloaded 514 times
Thank you for the attached sample. I tested the scenario and replicated the behavior. Indeed this seems to be an Advanced Installer issue when building an EXE setup package. A fix will be available in the future, thank you for bringing this to our attention. We will notify you when the fix will be out.
Until then as a workaround you should go to "Prerequisites" page and uncheck the "Check predefined launch conditions before searching for prerequisites" option.
This was fixed in version 15.0.1 of Advanced Installer released on July 9th, 2018.
