shenyongran
Shortcuts in the Quick Selection Tree
Shortcuts are in the main file together, want to control the shortcuts individually selectable
How to do it?
Sorin
Re: Shortcuts in the Quick Selection Tree
I'm afraid I'm not sure I fully understand your question. Could you explain which Quick Selection Tree you're referring to? A screenshot would be also appreciated.
Sorin
shenyongran
To do an example: Organize inside a separate control shortcut
Sorin
Indeed the shortcut to an installed file is placed in the same component as the file itself. This is the default behavior.
Please take a look on this article : How to create a shortcut only if a specific feature is installed?
Sorin
