PaulK
CustomAction Function Dropdown List
Hi All
Using Advanced Installer 14.5.2 Enterprise.
I have been testing the use of Call Function from Attached Native DLL. Using the test project that you have on youtube I have created the DLL CustomAction1.CA.dll. I created a blank project for a .NET application. Setting nothing else I go to Customs Actions and select Call Function from Attached Native DLL facilty and select the .CA.dll, now in the dropdown functions I can see :- CustomAction1, CustomAction2, zzzEmbeddedUIHandler and some others. Now when I run build and the msi file is created if I go back to Custom Actions and view the Function dropdown list for my dll I know see several duplications of the available actions :- CustomAction1, CustomAction1, CustomAction2, CustomAction2, zzzEmbeddedUIHandler, zzzEmbeddedUIHandler and others.. and everytime I do a new build the duplicated list gets longer? also if you change the Attached Dll to another one then the Functions list gets even longer...
Can you please me know what I might be doing wrong?
Look forward to your reply.
Image of what I see
Image of what I see
PaulK
Re: CustomAction Function Dropdown List
Hi
Does anybody have a reply to this problem?
Kind Regards
I tested the scenario and, indeed, I reproduced the problem. This seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
This was fixed in version 15.5 of Advanced Installer released on November 21st, 2018.
