Paulus999
Installer Version problem
Hi there
Hope someone can assist. Using version 14.5.2 Community version
Built Version 11.2.1 of a program called LOADIT and installed it
Built Version 12.3.4 of the same program but configured as an Update to replace existing version
When Installed, it replaces all the software in the installation folder but the Control Panel shows both versions (See below)
Any assistance gratefully received
Re: Installer Version problem
Hello and welcome on our forums,
This could happen if you did not use the same UpgradeCode for both versions of your setup package. You can check this from "Product Details" page -> "Product IDs" tab.
Also, please take a look on our "How to upgrade an older version of the package" article which could be useful for you.
Paulus999
Hi Daniel
Thanks for the reply
Unfortunately I cannot see a product ID's Tab on that screen
Paulus999
What I have done is opened the AIP Files for both versions and can see the following
Original Version
<ROW UpgradeCode="[|UpgradeCode]" VersionMin="0.0.1" VersionMax="[|ProductVersion]" Attributes="257" ActionProperty="OLDPRODUCTS"/>
<ROW UpgradeCode="[|UpgradeCode]" VersionMin="[|ProductVersion]" Attributes="2" ActionProperty="AI_NEWERPRODUCTFOUND"/>
New Version
Not sure if this is what you mean but they look the same to me.
Thx
Can you please send us the .AIPs (project files) to support at advancedinstaller dot com so we can investigate their settings?
Paulus999
Will Do and have also attached the files here
LOADIT.aip
LOADIT 1
(21.63 KiB) Downloaded 271 times
LOADIT.aip
LOADIT 2
(21.42 KiB) Downloaded 277 times
Hello Paul,
Yes, it seems you projects have different UpgradeCodes, this mean they are not upgrade compatible.
To be upgrade compatible you should proceed like this:
1. open the setup project of your 11.2.1 ProductVersion
2. go to "File" menu -> "Save" -> "Save as" option and save a copy of your project into a new location on your disk
3. go to "Product Details" page and increase the version of the "Product Version" field and build the upgraded version of your setup package
The above are the steps to proceed with when you want to build upgrade compatible products.
Paulus999
Ah - the light finally dawns
Many thanks for your time on this Daniel
You are always welcome Paul.
