Sehremis
IIS ~ Configuring ASP.NET .NET Error Pages
Hello everyone,
my Advanced Installer project is coming along nicely. However, just now, I've run into something that I can't figure out how to do.
During the installation, the installer correctly set ups an IIS web page, and that web page works just fine, running an ASP service.
However, now I want to add a custom .NET Error Page. Advanced Installer provides an option to create normal Error Pages, however, I can't figure out how to make it create entries for the .NET Error Page feature found in the ASP.NET section.
2018-01-26 IIS .NET Error Pages Configuration.png (105.96 KiB) Viewed 9768 times
Specifically, the steps I still have to do manually at this point are: Is there any way to do this directly using Advanced Installer? And if not, is there a way to do it, say, by PowerShell script?
Thanks in advance,
Kira Resari
Re: IIS ~ Configuring ASP.NET .NET Error Pages
Hello Kira,
Unfortunately we do not have built it support for this. I've added this improvement on our todo list and hopefully we will develop it in the future. We will update this thread when such improvement will be available.
Until then as a workaround, you can use our "Custom Properties" support to defined the >Net Error Pages. Here are the steps to proceed with:
1. download the attached "NetFx40_IIS_schema_update.xml" file and replace it in the Advanced Installer installation folder:
C:\Program Files (x86)\Caphyon\Advanced Installer 14.5.2\resources\iiscustomproperties\definition
just replace the existing one with the one downloaded from this thread
(3.43 KiB) Downloaded 760 times
2. restart Advanced Installer and open your project
3. go to "IIS" page and select the "Custom Properties" tab of your web site
4. add a new attribute and collection item as you can see in the attached sample project (created with AI 14.5.2)
sample.aip
(16.9 KiB) Downloaded 687 times
5. rebuild and test your setup project
Let us know if this helped.
Hello Kira,
This improvement has been added in version 18.8 of Advanced Installer, released on October 20th, 2021.
