janisito
Combo Box broken?
Using Advanced Installer 14.5.2 it seems it is no longer possible to edit the Control Data of the combo box. It is always greyed out. Happens to already existing combo boxed but also if you try to add a new combo box in a new dialog. Seems like a new bug, or is there some other way to get to the control data?
[img]
Combo Box - Can't get to Control Data
Combo Box.png (29.5 KiB) Viewed 4004 times
[/img]
Regards
Janisito
Sorin
Re: Combo Box broken?
Hello Janisito,
Yes, I can reproduce and confirm this issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
Until then, as a workaround, in order to open the "Control Data" you could double click on the combo box.
Sorin
