F8Marie
Desital Sign failed
I use Advanced installer Ver14.5.2 build 83143 with Windows10.
This is not an issue in other PC (Windows7).
Is installed WindowsSDK wrong?
When AdvancedInstaller runs I get this:
Checking builds status
Build required.
[ DefaultBuild ]
Building package: D:\UC-1\TOPS\Install\TOPS\setup.exe
Prepare build
Preparing files
The digital signing of the APPDIR\BuildPileAK.exe file failed. Error message: ''
Error details
Error details
Advanced Installer 14.5.2 build 83143
*** Stack Trace (x86) ***
[0x76e108c2] RaiseException()
[0x02c29372] -----
[0x01936b92] -----
[0x0193385b] -----
[0x01933516] -----
[0x01b55374] -----
[0x01a882db] -----
[0x016a9934] -----
[0x016a993c] -----
[0x015ee488] -----
[0x015f5b7c] -----
[0x023a8c80] -----
[0x01e08be1] -----
[0x77b94a77] RtlGetAppContainerNamedObjectPath()
[0x77b94a47] RtlGetAppContainerNamedObjectPath()
[0x01340000] MODULE_BASE_ADDRESS
Re: Desital Sign failed
I'm not sure why you encountered the related behavior. In order to further investigate this, can you please send us the .AIP (project file) to support at advancedinstaller dot com? If it contains confidential information you can send us a small test project which reproduce this behavior.
F8Marie
Thank you for your support.
I send you the AIP file.
Marie
F8Marie
Can you tell me about the progress on this?
I'm really in trouble.
Hello Marie,
This is still under investigation.
We apologize for the delayed reply, but we didn't find anything useful by now. Please give us a bit more time to further troubleshoot this and we'll get back to you as soon as we have more details.
In the meantime could you try to manually sign the setup package using SignTool.exe and see if the signing operation succeeds? Just disable the signing option from "Digital Signature" page, build the setup project and then try to manually sign it using SignTool.exe.
Hello Marie,
We ran lots of test with your setup project settings, but weren't able to replicate the build signing error. Also, looking over your attached setup project we didn't notice any "BuildPileAK.exe" file added in "Files and Folders" page.
Could you please try to manually sign using SignTool the above "BuildPileAK.exe" file and make sure the signing operation succeeds?
F8Marie
Dear Daniel
When I uninstalled the Windows SDK(Ver.10.0.16299.15) and I installed its (Ver.10.0.15063.400) again, It was succeed.
The advice from you was very helpful.
I am grateful for your great effort and support :D
Sincerely,
Marie
You are always welcome Marie.
Thank you for your follow up on this. I'm confident that your feedback will be useful for future users too.
