I'm having problems with the uninstall of our MSI on a Windows Server 2012 R2 X64 machine.
The install works fine.
The uninstall starts with the standard "Are you sure you want to uninstall this product?" message, I select "yes".
I then get a few quick progress bars then nothing.
I should get, at least, a "Finish" dialog.
The 32bit version of this install works fine on Window 10 Pro.
Ideas?
