elou
Label not Visible on dark Background without bootstrap
I would like Advanced Isntaller to set the "Override high DPI" Compatibility by creating the short cut.
You could I archive that?
Regards, Éric
Re: Label not Visible on dark Background without bootstrap
Hi Eric,
Try using Process monitor to see where that setting is saved in the OS and then replicate it into a setup project.
Usually such settings are stored in the registry.
