aho
AI_ExePath - delete it?
I need to reorganize my Advanced Installer Project. Therefore, some Features shall be deleted.
I have already deleted all the files (in the "Files and Folders" page) which were part of the feature "MainFeature_x86".
But when I look at the "Organization" page, I cannot delete the Feature "MainFeature_x86", because it contains an "AI_ExePath" component.
I could delete this componente, but since I do not know why this component is there, I'm not sure if this will cause troubles in the future.
2018-02-23 10_38_20-AI Forum.png (18.84 KiB) Viewed 23229 times
:?: What does this "AI_ExePath" component and is it save to delete?
Thanks a lot!
Re: AI_ExePath - delete it?
Hi and welcome to our forums,
This component is used by the setup package, you should not delete it.
Just move it (drag and drop) to another feature from that package that always gets installed.
aho
Thanks for the fast reply!
What do you mean with package? The Advanced Installer project?
In fact, I have several features where sub-features (which I want to delete) have this AI_ExePath component. Can I move all those remaining AI_ExePath components to "MainFeature" which will always get installed?
aho
I would be very happy about an answer.
By package we mean the MSI file that results when the project is built.
You can move that component to "MainFeature" from any feature that you want to remove.
aho
Thanks a lot!
You're welcome.
aho
I just noticed, that moving those AI_ExePath Components between "root-level" features is not allowed (drag'n'drop doesn't work). I can only move them between sub-features.
I also noticed the following:
In the past I added prerequisites. Features were automatically created for those prerequisites. I moved them inside another root-features.
Now I deleted some of the prerequirements, because I don't need them anymore.
It looks like, everytime I delete a prerequisite, every component of the corresponding feature is deleted - except the AI_ExePath. This AI_ExePath seems to be moved one level up (inside the root-level feature). The sub-feature is deleted only for the first prerequisite I delete. When I delete another prerequisite (which feature is also a sub-feature inside the SAME root-level feature), the AI_ExePath cannot be moved one level up, because there is already an AI_ExePath component. Therefore the sub-feature remains with only on component - the AI_ExePath.
Now the project is messed up, because it contains features which should not exist anymore.
:?: How can I get the project clean again?
I added an improvement on our TODO list regarding the "AI_ExePath" component, so it will not cause such problems in the future. Thank you for bringing these scenarios to our attention.
Meanwhile, as a workaround, you can follow the steps below:
- drag and drop that component to any other component from the project, so all the "AI_ExePath" components will disappear
- expand the component you moved it to, click on the "AI_ExePath" entry and "Move it to a New Component"
- drag and drop the new AI_ExePath" component to a feature that will always be installed
- remove all the features that you do not need anymore
aho
Thanks for your answer. Unfortunately I have some questions regarding the workaround.
Eusebiu wrote: - drag and drop that component to any other component from the project, so all the "AI_ExePath" components will disappear
.) Which component should be moved? AI_ExePath?
.) How can a component be placed inside another component?
Eusebiu wrote: - expand the component you moved it to, click on the "AI_ExePath" entry and "Move it to a New Component"
.) Do you mean feature instead of component?
Eusebiu wrote: - drag and drop the new AI_ExePath" component to a feature that will always be installed
.) You mean there shall be one feature which contains all AI_ExePath components? Is it possible that a feature can contain componets with the same name?
Yes, the "AI_ExePath" component should be moved to any other component.
Just drag and drop that component over another component.
No, I mean the component you moved "AI_ExePath" to.
There will be one feature that contains only one "AI_ExePath" component, this will be enough. A feature cannot contain more components with the same name. The "AI_ExePath" component that you see in all the features is actually the same component shared between all those features.
aho
I had more than one AI_ExePath components from already deleted prerequirements. I just needed to do your described steps once. After that, all other AI_ExePath components disappeared. Guess this is because it is a shared component...
Looks good now! Thanks a lot for your support!
You're welcome. I'm glad you solved this.
