vishwashashidhar
Add / Remove Programs Entry Stuck
Hello Team,
I've got an MSI built using advanced installer. Everything works great.
However, when I uninstall the program on Windows 10, the uninstall succeeds but the entry gets stuck in the control panel.
I've checked support forums of Microsoft and suggestions that we need to remove the registry entries, tried that too, but there are no entries in the registry for these instances.
Can anyone throw some light on this please?
Re: Add / Remove Programs Entry Stuck
Can you consistently replicate this issue on multiple machines? If so, please send us your AIP (project file) by email to support at advancedinstaller dot com alongside a test case so we can further investigate the scenario.
For testing purposes we always recommend to be used virtual machines with clean states so that when something goes wrong you can easily revert to a clean state of the virtual machine.
shellm
I have a similar issue with one of my Installers (didnt try the other ones as those are server applications which will never get uninstalled).
The Entry is stuck there even after performing an uninstall (however, not all my prerequisites are deleted, but this shouldnt be an issue).
Tested on Win7x64
vishwashashidhar
Daniel,
Yes, we can consistently repro the issue on multiple machines.
I've sent an email with our AIP file. Kindly check the same and let me know if you need anything else.
Thank you!
Hello all,
Until now we did not get your sent email. Just to make sure you did forwarded your AIP to the correct email address, our email address is support at advancedinstaller dot com. Make sure you replace "at" with "@" and "dot" with "."
vishwashashidhar
Hi Daniel,
Please see attached the screenshot of the mail sent.
Regardless, I've fwded the mail again.
Screen Shot 2018-03-22 at 16.00.07.png (244.96 KiB) Viewed 8818 times
vishwashashidhar
Hi Daniel,
Looks like the mail is not getting delivered. So, I'm attaching the AIP file here.
Please take a look at it.
Screen Shot 2018-03-22 at 17.31.31.png (302.45 KiB) Viewed 8815 times
Hello Vishwas,
I've deleted your attached AIP for privacy reasons.
I'm not sure why the original email sent by you failed to be delivered. I forwarded this to our email service admin so we caninvestigate this and take proper measures in case something is wrongly configured on our side.
I have received two emails from you though and I replied back to you by email. Here is my email reply:
I've tested your project settings but I cannot replicate the behavior. The control panel entry is always removed.
Can you please send us a download link for your built setup package and a detailed test case we can follow to replicate the issue on a test machine?
Please let me know if you didn't receive my email reply by now.
vishwashashidhar
Hi Daniel,
Thanks for checking on that.
Unfortunately, I don't have the authorisation to share the executable.
Instead, can we do a remote session to troubleshoot this issue?
Thanks.
Hello Vishwas,
Unfortunately we are not available for remote troubleshooting. If you cannot share with us the built setup package, then please try to replicate the issue in a new sample project and send it us alongside a test case we can follow to replicate the issue. Without being able to replicate the issue on our side it is quite difficult to further investigate this.
Antarctica
I had a similar issue with some programs that have not been installed through Advanced Installer. The programs had been removed, but the entries were still there. When I clicked "uninstall" again, the interface told me something like "The program was already removed. Do you want to remove the entry?" So I guess this is an issue caused by a certain Windows 10 update and/or Windows installer update.
