DiegoCP
Show language dialog on upgrade
i have an issue regarding language dialog. I don't understand why the language dialog doesn't show on an upgrade, if someone could help me with this.
i installed version 1.1.2 and i reinstall the same version. The content is removed but the language dialog is not shown. Can we force the dialog to show?
(the option "Uninstall package with same version (if found)" is activated).
Thank You.
Best Regards,
Diego.
Re: Show language dialog on upgrade
Hi Diego,
Please keep in mind that this is the normal behavior. When the "Uninstall package with same version (if found)" option is enabled, the already used language is preserves, so the "LanguageDlg" dialog is not displayed anymore.
If you want to select another language, you have to uninstall the product manually from the "Programs and Features" list before reinstalling it.
