Hi Everyone
its me again and I apologize in advance if I am just being a bit feeble.
I have moved away from the vbscript concept in an earlier question and I am now trying to implement a VB.Net Wix dll.
I configured Advanced Installer to build as a single EXE setup (resources inside) and attached a Custom Action Call Function from attached native DLL. In the DLL function I am writing log entries using;
session.Log("message")
I have been testing this and updating the DLL code as I became more proficient with Advanced Installer and the VB.NET side, I got to the point where I had included a form in the DLL to be displayed if it wasn't a /quiet install.
My first issue is that when I run the install from withing Advanced Installer as singe EXE setup (resources inside) it appears to have stopped writing my log entries to the install log, when I recompile the install to single MSI setup (resources inside) the entries are written to the log. I have inserted a MessageBox message into the DLL function and it displays either for exe or msi but only the msi will write the log entries. So when I first started this process the exe would write the log entries and then just suddenly stopped doing it.
Is there a switch that I don't know about. (I vae tested from within Advanced Installer and as a command line execution from CMD (running as Administrator)
