Helan
Missing file ui_en.ail
I'm in the process of migrating our build server to a new virtual machine. One of our aip projects does not build on the new build server with the error message:
Checking builds status
Resources referred by the project are missing:
C:\ProgramData\Caphyon\Advanced Installer\Repository\dictionaries\ui_en.ail
This file "ui_en.ail" is present on the old build server and my developer machine, but not on the new build server.
Re: Missing file ui_en.ail
That is a repository dictionary automatically created when strings are translated or modified in a project. In order to be able to build your project on the new build server, you need to copy that file to the specified location on the new machine or you can remove its reference from the "Translations" page, "Dictionaries" tab.
Helan
Thanks for a quick reply.
This is what the dictionaries tab look like. We do not use any translations of this application. What items in the list can I remove?
You need remove the first item of the list in order to be able to build your project.
