blueye89
How to change directory of user.config file
Hello to all,
I have created my first installer using Advanced Installer and I have a problem to do something.
After installing my app and running it, I am getting a form which require an activation code that I will provide to a customer.
Customer will paste activation code and click register. Activation code is saved in : "C:\Users\<username>\AppData\Local\..." but in the subfolder called "xqP6jeS5BRsGZFj6y1\MyApp_Url_gkuxhdeyfm5busxlqdwbzlhzsaqkm0jk" which is created automatically after first exit of the application.
What defines the name of these sub-folders? I have expected that there will be a folder MyApp in "C:\Users\<username>\AppData\Local\..." where user.config file will be stored.
I am asking this cause I would like to delete user.config file during the uninstall process.
Any help is very appreciated!
Best,
Danijel
Re: How to change directory of user.config file
Hello Danijel and welcome to our forums,
From what you told us it seems the related sub-folders and user.config file is created by your application. Therefore it is not something controlled by the setup package. I recommend you to forward your query to your app developer.
We can help you only in what regards your setup package configuration and deployment process.
Just let me know if I misunderstood the behavior you are facing with.
blueye89
Hello Daniel,
Thank you for your reply.
I have solved a problem by creating a new folder with specific name and setting a properties on it during uninstall process (image in attachment).
It works fine but I noticed another problem. The application that I developed works like add-in to the main application "Autodesk Vault" https://en.wikipedia.org/wiki/Autodesk_Vault. By following the Vault SDK documentation, it's possible to make your application to get license or to provide read only access which doesn't need a license. It is easy to configure by replacing few lines in a app.config file in the VS project.
I have done it an I have created a standard MSI installer using VS, application is tested and works perfect.
I decided not to use default MSI installer but to create a setup with Advanced Installer so I have included a mentioned app.config file in Files and Folder section. App.config file is successfully copied during the installation process. I have started the application but it seems that application doesn't read app.config file and license is grabbed.
Is there something specific that I need to do with app.config file?
I don't understand how standard VS installer did what I wanted and Advanced Installer's setup file didn't do.
Best,
Danijel
Hello Danijel,
I'm glad you solved the first problem.
Regarding the "app.config" file, can you try to make a diff (for content and file permissions) between the config file installed by AI setup and by VS installer and let us know if there is any difference?
