Problem starting Java application as a Windows service
Having trouble running Advanced Installer? Got a bug to report? Post it all here.
Post Reply
vpuri
Post by vpuri » Thu Apr 05, 2018 12:29 pm
Problem description - I have a Java Spring Boot application that I converted to a Windows service using Advanced Installer. When I attempt to start the Windows service using the Windows Service Control Manager (SCM) or sc.exe on a Windows 2012 server, I get the error, "The service did not respond to the start or control request in a timely fashion.” error. However, the logs created by the service indicate that it started. Also, I can execute the service executable created by Advanced Installer manually and the java application starts without any issues.
How to reproduce ? - The main class for a Spring Boot application needs to be initialized to "org.springframework.boot.loader.JarLauncher" and not the application's actual main class.
vpuri
Re: Problem starting Java application as a Windows service
Post by vpuri » Thu Apr 05, 2018 5:11 pm
I forgot to specify the Java "Application Type" as "Win32 Service" when configuring the project. Setting this properly allows the service to start.
Post by Eusebiu » Wed Apr 11, 2018 1:20 pm
Hi and welcome to our forums.
I'm glad you solved the problem. If you get into other issues, just let us know.
Post Reply
