elou
Issue with "remove folder" do not remove the folder
since I've updated from AI 14.5.1 to 14.7 the synchronized directory, marked as beeing deleted, will not be removed before the new files are installed.
This issue forced me to roll-back to 14.5.1 (and it was hard work to find the issue :( )
Regards, Éric.
Bildschirmfoto 2018-04-10 um 08.30.39.png (161.62 KiB) Viewed 7312 times
Re: Issue with "remove folder" do not remove the folder
Hi ,
This is, indeed, an Advanced Installer issue that will be fixed in the next version of the application. The workaround for this was to uncheck then recheck the "Remove Folder" option and rebuild the project. Sorry for the inconvenience.
elou
thx for your reply. I've patch the project as you describe.
I had the save the project between deactivating and activated under AI 4.7.
But I could not saw any correction. The bug is already present. The workarround do not work.
Regards, Éric.
Hi Éric,
I'm not sure why the workaround didn't work for you. Can you try to rebuild your project with version 14.8 of Advanced Installer that includes this fix and have just been released and see if it works?
elou
Hi Eusebiu,
issue is now fixed with 14.8
Regards, Éric.
Hi Éric,
I'm glad it works. Just let me know if you encounter other problems.
This was fixed in version 14.8 of Advanced Installer released on April 16th, 2018.
