Mikhail
Multiple "uninstall" buttons on Add or Remove programs page.
Hello.
My java desktop application uses updater /checknow command on start to update to new version if new version is found. I noticed that each update adds new button "Uninstall" on System settings 'Add or Remove programs' but previous buttons are not deleted. So after 2 updates I see there 3 row with my application name. What is the reason?
Thank you.
Mikhail.
Re: Multiple "uninstall" buttons on Add or Remove programs page.
Hello Mikhail,
Thank you for joining our forums community.
This behavior could appear if you configured your setup projects to allow side by side installation of different versions of the product. Just go to "Upgrades" page and make sure that the "Allow side by side installs of different product versions" option is selected.
Otherwise, the same behavior could appear if you didn't follow the major upgrades or patch setup build workflow.
In case of a major upgrade you should increase the product version (one of the first three fields) and choose the option to generate a new product code.
In case of a patch compatible setup project you should just increase the product version (one of the first three fields) and choose the option to keep the same product code.
Also, please make sure that you are always changing one of the first three fields of the Product Version when building a new version of the setup package. Windows Installer ignores the fourth field of the Product Version.
If this is still of no help then, please forward us your AIPs (project files) to support at advancedinstaller dot com so we can investigate their settings.
Mikhail
Hello Daniel.
Thank you for detailed answer. I think I solved issue. I use Advanced Installer release 13.4. I found that Uninstall doesn't work if I use wizard, "Silent Installation" and check "Override .."/"Use a single .." in Product Details. In that case after click "Uninstall" button popup window "Configuring ..." appears and it never be closed. But I couldn't reproduce this issue on release 14.8. My workaround for release 13.4 is selection "Disable Modify" and "Disable Repair" instead of "Override Windows ..".
Best regards.
Mikhail.
Hello Mikhail,
Thank you for your follow up on this.
I'm glad yo got everything working by using our latest version of Advanced Installer (14.8).
