Tushar
Digital Signing Not working with External SignTool from Microsoft SDK
I am using digicert code signing certificate with Microsofts SDK signing tool.
I had downloaded MS SDK for my Windows 10 OS. The system is 64 bit but the SDK is 32 bit.
The path is: C:\Program Files (x86)\Windows Kits\10\bin\10.0.16299.0\x64\SignTool.exe
here is the detailed message:
The digital signing of the APPDIR\iMedXExpressEditor.exe file failed. Error message: 'Error information: "Error: Store::ImportCertObject() failed." (-2146885630/0x80092002)
SignTool Error: An unexpected internal error has occurred.'
Advanced Installer 14.8 build 281f49a4fb
*** Stack Trace (x86) ***
[0x743bd8a8] RaiseException()
[0x01c1a412] -----
[0x00a1847a] -----
[0x00a15ac7] -----
[0x00a157d6] -----
[0x00c11254] -----
[0x00b48f50] -----
[0x007c85de] -----
[0x007c85e6] -----
[0x0070d543] -----
[0x0071673c] -----
[0x013d05c0] -----
[0x00e689c1] -----
[0x771c5663] RtlUnicodeStringToInteger()
[0x771c562e] RtlUnicodeStringToInteger()
[0x00350000] MODULE_BASE_ADDRESS
[img]
[/img]
Tushar
Re: Digital Signing Not working with External SignTool from Microsoft SDK
More information about the issue:
If I use digisign.exe then it is still not able to sign the files.
The digital signing of the APPDIR\iMedXExpressEditor.exe file failed. Error message: 'digisign.exe error. System error code: 2148081666. Error message: An error occurred during encode or decode operation.
digisign.exe sign /f E:\Documents\DigiCertFiles\iMedXInc.p12 /p xxxxxxxx /d iMedXExpressEditor /fd SHA256 /tr http://timestamp.digicert.com /td sha256 '
[0x022da412]  -----
[0x010d847a]  -----
[0x010d5ac7]  -----
[0x010d57d6]  -----
[0x012d1254]  -----
[0x01208f50]  -----
[0x00e885de]  -----
[0x00e885e6]  -----
[0x00dcd543]  -----
[0x00dd673c]  -----
[0x01a905c0]  -----
[0x015289c1]  -----
[0x00a10000]  MODULE_BASE_ADDRESS
Tushar
This has been resolved.
This was a problem with my certificate.
Thanks much.
I am putting my problem and resolution here it might be helpful for others:
I have Microsoft Authenticode digicert certificate. I installed it using FireFox and exported it as .p12 file.
running with signtool also gave me the same issue.
signtool sign /tr http://timestamp.digicert.com /td sha256 /fd sha256 /f "path to certificate file\Certificate.p12" /p xxxxxxx "path to.exe" SignTool Error: An unexpected internal error has occurred.
I used the digicert certificate utility to reexport the certificate as .pfx and that resolved the issue.
-Delete the existing certificate from the utility.
-import the .p12 file.
-export the certificate as .pfx with password.
configure .pfx file with password with Advanced installer.
Thanks much.
First of all I'm glad you got this working.
Also, thank you for sharing this with us, I'm sure it will help further users with a similar situation.
