MrZ
Adding new build will break the custom dialog
Hi, I've authored a functional ai installer with a custom UI (defaultbuild). I added an additional build and compiled it. But when I run the newly build setup file, it will show a nonfunctional Install dialog. see the attachment.
Clicking the install button doesn't trigger anything. What happen?
Note: The only way for me to fix this problem is by switching to other theme first and set it as current, causing all the custom changes to disappear. And then I have to switch back to the Surface theme and redo all the changes, manually.
failed
failed
success
success
Re: Adding new build will break the custom dialog
Please read the "Why are my dialogs and controls not displayed correctly" FAQ which describes why your problem appears.
