aho
Installing Visual C++ Redistributable fails
On some machines, when I run my setup wizard it fails with the following error message:
failed to launch file.png (10.56 KiB) Viewed 4944 times
This error occurs only on some machines.
Both redistributeables are installed as offline prerequisite.
Waht does "Error: 2" mean?
What can I do to solve this?
Thanks in advance!
aho
Re: Installing Visual C++ Redistributable fails
Does anyone have an idea what I could try to fix this problem?
Thanks so far!
This is a system error and means The system cannot find the file specified..
When this error occurs again can you please browse to the file location exposed in the error message (before pressing the [OK] message box button) and check if the prerequisite setup was successfully extracted there?
Also, for testing purposes only, if there is any antivirus program installed, can you disable it temporarily before launching the setup package and see if this helps. Maybe there is an AV falsely detecting your setup package.
The best way we can further investigate this will be if you could identify a test case or pattern when this behavior occurs.
aho
recently I had this problem again.
It seems, that the error message occurs, when the "same" setup wizard - but older version - is already installed.
In that case, the setup wizard for the redistributeables already exists in the APPDATA Folder.
If i delete this redistributeable setup an run my wizard again, it works.
What can I do to prevent this error message?
Thanks a lot in advance!
Andreas
Hello Andreas,
If the problem is solved by deleting the prerequisite's folder, then you can create a Custom Action, scheduled at the start of the installation which will search for the folder and, if found, delete it.
Hope that helps.
