sonda
Create Database
I'm new to advanced installer and i wonder how can i achieve this : before installation to check if database exist if not to create, i added new SqlConnectionDialog:
: Added new predefined sql connection
selected option if database not exist to create also log errors to file, but when i build installer and run installation database is not created neither error is thrown also not sure where to search the log, not sure if this is all required steps to create database and also how to log errors and stop installation if error occurred while database creation (server not available, invalid logon parameters ...)
thanks in advance
Re: Create Database
This could happen if you do not added any SQL scripts under the "Predef" SQL Connection you defined in "SQL Databases" view of your setup project. When no SQL Script or SQL Query is executed during installation the SQL Connection will not be established.
If no SQL Scripts are defined but you still want to use this option to create the database on the target machine, then you can add a script with a simple query. Something like:
USE database_name;
Hope this helped.
sonda
Re: Create Database
Hi Daniel, i succeeded to create database, thanks
Re: Create Database
You are always welcome.
sonda
Re: Create Database
How can i create database if database not exist if, i select SQLServerConnectionDlg?
sonda
Re: Create Database
The main question is if i use SQLServerConnectionDlg, and i select Trusted connection,
2018_05_15_16_29_08_ATS_Security_configuration_manager_ATS_Security_configuration_manager.aip_E.png
2018_05_15_16_29_08_ATS_Security_configuration_manager_ATS_Security_configuration_manager.aip_E.png (27.7 KiB) Viewed 6633 times
What i will have in [Username_Prop],
Will database be created if i enter not existent database?
Re: Create Database
When trusted connection will be checked in the SQL connection string (used by the SQL connection from "SQL Databases" page) will be inserted a trusted connection specific SQL parameter and the UID and PWD parameters will be removed form the connection string.
If you input a non existent database this will be created (with the exact name as you input) only if your SQL connection from "SQL Databases" page includes at least one SQL script which is executed.
USE database_name;
